1/8th mile track...I'll be happy for a couple of low 6's...60' times sucks with all the other problems and that's the key...6's? u're nuts! Fire that StunGun.. Can't wait to hear the results, you've been waiting for this day for a while, bro... Good luck and have a safe one
How much does it cost u to run at the strip?1/8th mile track...I'll be happy for a couple of low 6's...60' times sucks with all the other problems and that's the key...
$10 if you drive/ride...$15 if you tow...How much does it cost u to run at the strip?1/8th mile track...I'll be happy for a couple of low 6's...60' times sucks with all the other problems and that's the key...
Good luck and have aone
Don't expect the 60' to be any good...After being away so long plus I'll be running a Shinko...Yeah Stunnah! Get that thing running.
I'll be in NH tonight doing the same thing! Give me a shout! I'll be there from 6-10PM
Let me know your 60' times....
Yeah it could be the lag...No nos...I'll just continue to increase the rpm range...Wasn't comfortable the other nite trying to get the feel for the track...Could it be just turbo lag ?
Nitrous will take care of the lag Playa.
I should have put a Shinko on along time ago...I love it...Dropped the pressure to 20lbs and no wheel spin...Even feel more secure on the road I took to get to the track...It has lots of curves and the rear end felt alot better than it has...I've run a shinko with about 200hp and had no problems. Just gotta heat it up good. Good luck at tha track ! Be sure and post them #'s !
My 60' is gonna drop also with the fueling correction...Only solution for you is to put some inches on the rear...I bet your all in the air when you roll out...When I grow up I wanna be just like you...........Rick James.............
Just kidding.......My 60' suck compared to yours. i need to get this damn thing out of the hole better........
