Going to track tonite...
Well I thought I had the fueling worked out...But that was not the case...9-4-04 went to the track...First run 6.6 something @ 116mph I said yeah this is gonna be a good nite...Well times got higher and speed began to drop...Bike started to stutter up top...I'm like what the freak...Anyway was still to rich...Best I ran was a 6.40 at 116mph...60's sucked also lots of tire spin and I didn't let any air out...Gonna get it worked out...
is that with a stock swingarm? that sounds really low on mph and time. my stock motor turns 118 in the 1/8th at 4" over with 42 rear sprocket and 1.56 60ft
yea people just think you bolt sh...on and fly. i just put a 6-10" arm on my bike, about to put the brock sidewinder on. decided to go longer and try to spray off the line or around the 60ft mark. good luck with your turbo. go check out my website and sign up. www.pcpracing.net i work alot so i dont get to make it to the track very often and it is only an hour away. i see 130mph in the 1/8 for you
I'm hoping just to decrease the 60' and get into the low 120's...If I can do those things I'm hanging up the track...
