I'm not really interested in making over 300 HP at the tire,250-275 is more than enough,at the lower boost levels you can get away without a intercooler,lower boost=lower inlet temps,I guess this could be called a entry level system,the MC Xpress is more than likely the top dog kit right now,I run twin turbos on my 94 Cobra Mustang,and it is a intercooled kit.
If you read Hahn's website they mention using some kind of ignition retard system,that is a by-product of not using a intercooler,you have to retard the timing to stave off potential detonation,which in turn means less HP,the bottom line is a intercooled turbosystem will make more power with less chance of detonation and you can get away with 92 octane fuels at the higher HP levels.
Seb:How much is the MC Xpress kit???
