GOD
I just got my busa 2 weeks ago and had same problem(just needs to be adjusted).......the easiest way to adjust is to go through bottom......the trick is the way you do it....take off the bottom cover(instructions located in owners manuel) lay on your back feet facing same direction as bike, with your right shoulder touching the front wheel....this way you can see what you are doing and you have room to move wrench to adjust screw(you may need to turn wheel left or right to get right position).....maybe taking off fairing easier(i didn't try), but this way is quick, easy, and you can adjust both beams at the same time without going through top and bottom!
