RedBull
Wow! That looks pretty bad! Hang in there, I’m sure the guys that have dealt with this in the past will be on here to give you some advise.View attachment 1585322View attachment 1585324View attachment 1585325
Hey guys!!!!!
Please help me out this till date recovered condition of throttle body, fuel pump and tank.
Throttle body: Heavy gum deposits on take side, extreme gum deposits on intake valve
It may lead to engine damage.
Cylinder no. 1 fuel injector primary and secondary o ring is recovered to be piecred.
Heavy metal particle inside fuel tank.
Please guide how clean and proceed further.
Really? I'll just google that, need to check on brands and availability. . .Blinker fluid
Take the throttle bodies, fuel pump, fuel tank, injectors to a fuel system cleaning specialist workshop and have them professionally cleaned and checked over.wai
Waiting for his reply.....................................
OR SO THE GERMANS WOULD HAVE US BELIEVE.Really? I'll just google that, need to check on brands and availability. . .
The pump will need a new filter and the sock cleaned well.
You should also get a few cans of "upper engine cleaner"
and spray in to the intake ports to remove the carbon build up on the back of the intake valves.
Good luck, your bike's fuel system is one of the worst I've seen!
Ok, ok, the war ended back in'45 . . . just let it go Ali, let it go man and move onOR SO THE GERMANS WOULD HAVE US BELIEVE.
I USED to love norm on Saturday night live...Ok, ok, the war ended back in'45 . . . just let it go Ali, let it go man and move on![]()
Pumpkin preferably, but can’t pass a good hair piewhat kinda pie?
@himanshu23, have you made any progress in the cleaning of your bird’s fuel system?wai
Glad it's fixed. Is the environment harsh where you live? Keep up on your preventive maintenance and you shouldn't have these issues again.
