HAYABUSA WITHOUT EXHAUST
CVN
TOOK MY PIPES OFF, BUSA SOUNDS LIKE A 350 WITH A CAM IN IT, HAS ANYONE ELSE RODE LIKE THIS. ARE THERE ANY NEGATIVE EFFECTS TO BIKE.
(warbrown @ Apr. 27 2007,20:39)
(CVN @ Apr. 27 2007,12:31) ARE THERE ANY NEGATIVE EFFECTS TO BIKE.
I guess we could start with hearing loss...
I would worry about computer map. if not it might not be a good outcome ..
How about...why?
Here is my video of no mufflers at 10,000 RPMS.
  I did it for about a 10 min ride and put them back on.  If you really want loud try a brocks street megaphone system without the baffle in.  It is crazy.
Edit: Forgot to put the link in. Clicky clicky
(DaCol. @ Apr. 27 2007,18:43) Followed by burned pistons from a VERY LEAN condition
Wont happen, several members have their bikes the same way and have had for many miles with out any problems the burnt piston theory is just an urban legend
I changed the oil in my bike today (01 black and gray) and everything was great.  Rode about a mile parked and noticed a large pool of coolant on the ground under my bike.  I did not see any lose hoses.  Somebody help me please.
First was the temp running in the upper part of temp guage. Really, if you haven't had any trouble, I would first check the overflow. Check and see if your coolant level is correct (Left side in front of the gear shift pedal) and between the two lines. If it's above the top line, you probably just had an overflow. If it's below the bottom line, your low and should look and find out if it's leaking or has another problem. Check there first, then the lines for leaks.
PM Thrasherfox, he cut off the midpipes, and used a PC to remap it.
He's been running it like that for years now
(nuke1115 @ Apr. 29 2007,19:19) I changed the oil in my bike today (01 black and gray) and everything was great.  Rode about a mile parked and noticed a large pool of coolant on the ground under my bike.  I did not see any lose hoses.  Somebody help me please.
Mine was the radiator...bought a used one from Daniel, cloud 9.
thread jack
I kinda lost waht this thread is about..... your took the pipes of.. as in the whole system eincluding the headers? just the can?
For aero's when I race I go without my can. It's loud but not megaphone loud.
