Head Work
Indy03BUSA
Is there a place that I can send my head out to to have some work done on it.
How much Hp would you think you could get out of having head work done?
What would be a good set of cams to put in the Busa to get more HP?
Thanks all for the Help
Get your headers Jet-Hot coated and that will add horses all by itself....
Lots of places do head work. You may find a couple listed here
http://www.dragbike.com/directory/index.htm
You will definately pick up some power and how much will depend on how much you want to spend. You can get 220+ HP from Ward Performance for $3450. Ward, http://www.wardperformance.com/ ,  does some of the best head work you will find anywhere in my opinion. Head shop will advise you on a good set up for cams. Also keep in mind that headwork and higher compression is tough on a engine and you are oging to need to strengthen other parts of the engine so it will hold together. I would say a turbo is a better option. One last piece of advice. If you go ahead and get some work done, don't take it to your corner shop or buddy down the road. Take it to a very good head shop or you will run into problems.
<!--EDIT|Krieg
Reason for Edit: None given...|1119022550 -->
Jay, I don't know anything bout building a motor. but i do know what i want out of it. How much for a 200hp setup thats nos (50-60shot) ready ? Exchange of course.
Call Lee's Performance in Charlotte 704-599-1507 . He'll hook you up with a little HP
Me and C Henry are within a couple of hundre miles of each other, anyone got any ideas for the mid-south?
Leave your Head alone! Spend some money on a set of drop in cams.... Yosh would be my first choice for a stock bore bike...
Both jonny C. and Carpenter are a little far away for me. When i do get ready for motor work, think I'm gonna try Cooper performance in S. Ga.
