Headlight Modulator with Adjustable Daylight Sensor
Speed King
Banned
Has anyone ever used these on there bike? Motorcycle Headlight Modulator selection page - VisiPath.
Most drivers don't see motorcyclist immediately because cycles blend in with the traffic and surroundings.
Be SEEN!
Helps avoid someone turning in front of you from a driveway or other lane.
World's smallest headlight modulator1
Fits street, cruiser, and other bikes
OK for use under Fed regulations in United States and Canada with light sensor
Single or dual headlights
User adjustable daylight sensor
EZ Install just plug-in
Smallest bulb connector to fit into tight spaces - almost 40% smaller than other modulators!
Automatic darkness deactivation - light sensor stops modulation when darkness arrives
No hole drilling to mount sensor
Solid state circuit - no mechanical relays to worry about
Waterproof and heavy duty design
Lowest ON resistance for the brightest bulb possible
Controlled by your bike's Hi-Lo beam switch
No wire cutting or splicing
Requires 12 volts DC
Scooter - make sure headlight bulb is DC operation
100% tested twice and guaranteed working before shipment to you
Very small size to fit inside most headlight housings
Seemed like a great idea till I read some posts concerning safety. One negative is drivers will think your 'flashing' them to give the OK to turn in front of you.
I know I see them around here occasionally and I know a few members here use them. I personally don't though. I also know that they don't work with HIDs so if you have HIDs you won't be able to use this.
I think some of our site sponsors sells headlight and brake light modulators too.
I used them before I switched to HID. They are very effective. Helps clear the drivers sleeping in the left lane.
