HELP ME IDENTIFY THESE MODS PLEEZ
lisafrank06
i found this pic on google and i want to get the same model and mod it exactly the same! can anyone tell me what year this busa is? can you tell how it was modded (lowered/ how much?, aftermarket body? extended swingarm/ how much?) any recognizable mods that you can note to help me, with limited knowledge, to recreate this bike from a stock model?
THANKS IN ADVANCE FOR ANY
HELP...I'M IN LOVE WITH THIS BIKE!!!!
I don't think you'd want it exactly.
That racing slick would make street riding very............. eventful.
I'll guess 2000 Busa, stock Bodywork, cut down stock seat with home made pad on the hump, Trac Dynamics arm 10-14" longer than stock, looks like it could be a Micron Pipe sans tag. lowered 2" both ends. Again these are only guesses.
Front wheel is from an 04' (Red) or 05'(Gunmetal) LE. Along with the black frame I would guess it is one of these two years and the body work has been painted black.
double bubble windscreen, smoked headlight and turn signal lenses
Lack of gold Forks and calipers make me question its being an LE.
Looking the whole thing over, it appears to be a "JunkYard Dawg".
Pieced together from a few different,.....machines.
Cool Concept, though.
the swingarm is a zook arm about 8-12 looks like about 1.5 inch in the rear lowered or running a straight link at stock height
no decals...no reflectors....lookslike paintedor powder coated rearset....cant tell on the pegs, possibly buell or TL's....mirrors removed
its also possibly a turbo bike with the hmf big bird exhaust on it, dont know though
Lisafrank06 check your PM.
To me that bike looks like a piece together. and with that much drop on the streets will be impossible (ive done it). Plus it almost looks like someone has Necked that bike (tilting the neck to i higher degreed rack for drag use), reason i say that the front wheel is kicked out way too far to be stock and the fork tube rake is off.
But i may have what your looking for, like i said check you PM
Junkyard / ebay build... either an LE frame or a painted one raked
aftermarket top yoke spacers to allow tubes to slide higher (lower front)
looks like 99-00 front end with that axle
front rim looks like the lip was stripped (paint removed)
chromoly 10-12 over arm
prob 3 hole dog bones (lower rear)
can't see the rear wheel but it's def not stock w/slick
extended rear brake line
hacked undertail
hacked seat
added hump pad
removed bar ends
removed mirrors and added washers
body re-paint black
dunno the exhaust or hanger
prob rattle can black lenses
ebay clear doublebubble screen
Can't see much else... what's odd is that it has a slick (dedicated drag rear) but has dual front brake rotors. seems like a pos
