Help Me out with Flasher mod!
mikey28804
About 3 months ago I did the flasher mod. Worked like a charm! Then I took the nose if my bike off to install a new ignition. When I plugged it back on the turn signals were just solid. No blinking. Then I went and bought a new flasher hooked it up like the other and It works....BUT one issue. when I turn the turn signal off It still conintues to click like the signal is on.....Im lost
The onlu issue is I used an ep-35 on the first one and by mistake picked up an ep-36 today.....the only difference between the 2 I see is the 35 is for 2-4 lights and the 36 is for 4-6. should it still work right or do I need the 35?
