Help needed rear tail light ???s
Black = Ground
Red = Brake
White = Running
Blue = Left Signal
Yellow = Right Signal
Either can be ground for Tag Light
according to what's on ebay:
All Black with white stripe wires should tie to Black ( neg or grd ). Red should tie to White with Black stripe (Brake). White should tie to Brown (Running). Blue should tie to Blue (Left Signal). Yellow should tie to L ( Right Signal ) ( lavender ? couldn't make out on drawing. It's the only wire left ).
THANKS FOR ALL THE HELP GUYS, after messing around for a little longer, come to find out the damn aftermarket tail light was wired incorrectly the only wire that was correct was the running light. the ground and brake were reversed. EVERYTHING is working correctly NOW.................
