Do you polish yours once a week?(BA BUSA @ Feb. 07 2007,12)But the other ones are purty
You got that right, pretty dayum expensive compared to the Reaper B/O plates.(BA BUSA @ Feb. 07 2007,09)But the other ones are purty
(BA BUSA @ Feb. 07 2007,12:40) I polish it EVERYDAY
I did mention the FREE way to do it(Rhythm @ Feb. 07 2007,09:41)You got that right, pretty dayum expensive compared to the Reaper B/O plates.(BA BUSA @ Feb. 07 2007,09)But the other ones are purty
You always have to be right, dont you !(BA BUSA @ Feb. 07 2007,09:45)I did mention the FREE way to do it(Rhythm @ Feb. 07 2007,09:41)You got that right, pretty dayum expensive compared to the Reaper B/O plates.(BA BUSA @ Feb. 07 2007,09)But the other ones are purty
It's not that often that I am right(Rhythm @ Feb. 07 2007,09:53)You always have to be right, dont you !(BA BUSA @ Feb. 07 2007,09:45)I did mention the FREE way to do it(Rhythm @ Feb. 07 2007,09:41)You got that right, pretty dayum expensive compared to the Reaper B/O plates.(BA BUSA @ Feb. 07 2007,09)But the other ones are purty
That's odd I didn't get any shavings in my engine(heavybusa @ Feb. 07 2007,10:43)Good call, glad the experts are here.(BA BUSA @ Feb. 07 2007,11:39)+1 you're going to get some metal shavings into your engine(Rhythm @ Feb. 07 2007,08:31)If you want metal shaving in your block !(jjmetheny @ Feb. 07 2007,07:06) A 6mm tap and bolt works great. Some use a self tapping type bolt so they don't have to tap the hole.
Did you tap the hole(jjmetheny @ Feb. 07 2007,14:38)That's odd I didn't get any shavings in my engine(heavybusa @ Feb. 07 2007,10:43)Good call, glad the experts are here.(BA BUSA @ Feb. 07 2007,11:39)+1 you're going to get some metal shavings into your engine(Rhythm @ Feb. 07 2007,08:31)If you want metal shaving in your block !(jjmetheny @ Feb. 07 2007,07:06) A 6mm tap and bolt works great. Some use a self tapping type bolt so they don't have to tap the hole.
Ya, the oil pan after they made it past the valves and then past the rings(heavybusa @ Feb. 07 2007,17:16) how would you know? Oil pan? would they go that far?
Yes, with a 6MMX1.0 tap.(BA BUSA @ Feb. 08 2007,00:38) Did you tap the hole
