nskyline34
Have a Can-Am x3 UTV that I'm swapping a Hayabusa into for my YouTube channel, and I want to add a turbo to it eventually. But I'm starting to think that rather than do it later after I've already fabricated motor mounts and everything, that it might be wise to do it now so that I know it all fits and I dont have to redo as much later on. This turbo will never have to supply more than 300-325hp because I'm not going to tear down the engine to do everything needed to make it survive at that level. Whatever you can do on a stock pump gas 2006 engine will be fine. Only thing I MIGHT do is a spacer - but there's only about a 10% chance I'd do that even.
I need something that will be quick spooling so it has as much bottom end torque as possible (yes, I know you're never going to get torque from a 1.3L lol) since the X3 weighs just a little more than a busa does.
I'm wondering what turbo specs the RCC 1 kit is or if there are charger specs that would work better for my application then I'd really appreciate the feedback? I was thinking something like this: Basically a GT2560 or GT25/GT28 hybrid turbo? Or...?
Specs:
GT28 Turbocharger
3" Inlet Diameter
Journal Bearing - Wet Float Type
Internal wastegate set at Max 25 Psi
Garrett 4 Bolt Down-Pipe Flange
T25 Flange
Oil Lube, Oil/Water Cool
Ideal for smaller displacement engines making up to 420hp
Compressor Wheel
0.60 A/R Cold Side
Ind: 54.00 mm
Exd: 70 mm
Trim: 60
Turbine Wheel
.64 A/R
Ind: 52.90 mm
Exd: 45.47 mm
Universal GT28 Turbocharger T04B 0.60A/R T28 0.64A/R GT28+Internal Wastegate | eBay
Universal, Great for all DIY Turbo Upgrade Projects. If a part was successfully installed, went into service, and then failed, it may be eligible for warranty repair. IMPORTANT NOTICE.
www.ebay.com
Specs:
GT28 Turbocharger
3" Inlet Diameter
T25 Flange
Compressor Wheel
0.60 A/R Cold Side
Ind: 54.00 mm
Exd: 70 mm
Trim: 60
Turbine Wheel
.64 A/R
Ind: 52.90 mm
Exd: 45.47 mm
