eschmidt155
On my 2nd harness. I completely isolated the new harness. With the red wire marked 12v to kill switch, blue ignition wire to switch on dash and starter wire to starter button. I have the fuel pump wired directly to harness wire marked fuel pump hot. I removed fan, water pump , power commander and gear indicator wires. I've paid several mechanics and all have different ideas on what the issue is. I spent 4 hours with a mechanic yesterday and something strange occurred, the red 12v wire had 12 volts coming out of it!! WTF!!! The 30 amp fuse blew, we changed it and it no longer had power coming out of it for the rest of the day.
I'm going to cut open this harness tonight and see what I find, the last one had some melted red wires by the starter relay. If I were you I would do the same before you fry another ECU.
