I used to make em' up with an old selonoid linking the two batt's , with a toggle in the cab to flip back an forth between the two
Is this setup like a battery isolator maintaining a charge on
"both" batteries even when the secondary is not in use ,but with a switch to choose which battery to use?
If so what which wire from the rectifier on the Busa can I tap into using this type of switch to maintain two batteries?
I've been thinking of doing a mod like this for added accesories (full heated suit,radar,gps and Nomad 20 gig jukebox) using an 90 amp battery islotar with a secondary deep cycle sealed battery. With this setup I will just hook all of my accessories to the second battery which will recieve a charge as needed from the alt via "battery isolator" and no worries of placing a strain or draining the primary batt while the bike is running or turned off.[/QUOTE]
personally Ryth I wouldn't bother . Most m/c accessories are built to draw very little , my electric vest for example draws .5
thats close to nothing,gps,radar,those things pull next to zip aswell . But if you've got a spot for a second battery , the quikest an' easiest way , the way I would go , (obviously yer not concerned about weight) would be to split the + going to yer battery into 2 , one main positive for each battery . Both of course get grounded to the frame . Then each main gets a switch . You then alternate each day , letting each battery take a turn a powering yer mobile entertainment center and getting charged by the stator. Its a great anti-theft device too , when yer away from yer ride,you can turn 'em both off,no juice to ignition circuit no matter what the purps do . The reason I'd go this type of route is so as not to mess with the stator directly, also you cant expect to ride around charging an "accessories only" battery because something has to power yer ride at all times while its running . Both batteries will have to share the same duties . Make sense?
