04LE
Hi guys starting a retrofit using mini H1 projector setup gen2. Running into some issues that i am hoping you can answer for me. The 1st picture i think i also need to take the dremel to get the hole a little wider so that that screw part can push through. I think that is the only hold up with that part.
Then the 3rd pic on the back side of that piece i have removed those fingers but the dome glass of the projector doesn't push through. Should i be taking the glass off and then putting that on the outside like how the factory projector was?
Haven't started the low beam yet but looks like i have to cut the shroud a bit to get it in there.
Thanks for any help!
-Tom
-Tom
