Looking for some advice. I have attempted to turbo my stock '07 Busa. I took the cheap route and am now paying for it. Bike overheated many times and I came to the conclusion that I had blown a head gasket. Motor is torn apart now and pistions and valves are bad. I have ordered the JE piston kit, 83mm with a 9.5:1 ratio and H Beam Carrillo rods from Orient Express. I also and replacling the cylinder stud and nuts with the APE version from Orient also. Valves are being replaced also with OEM. What else should I do to make sure I don't fully destroy my engine? The turbo was the, OMG F.A.S.T. 250. I have seen the blogs, but it was alittle late for me. Already on the bike. Any constructive advice is appreciated. Thanks to all!!!
