Never changed them out, but you may want to let some penetrating oil soak into the gap overnight, and then like you said...a couple of strap wrenches.
Make sure you also try to go easy vs. brute force. When there's a tight fit, ANY misalignment will cause the parts to bind. You more of a wiggling, then trying to force it.
