horse power
edubb37
I have a 08 busa stock with yoshi rs3 full exhaust i want to know how much I have now and what can I do to get a little more power without spending a lot of money
Posted via Mobile Device
To get the most power from your exhaust, look into getting the ECU Editor and then have your bike dyno'd by a capable tuner.
tuning using ecu editor with a person who really knows what they are doing!!!!!!!! that is the cheapest way to get the most boost. as stated above. forget the power commander if you can get the ecu editor done.
The cheapest power maker is a Schnitz Racing sticker. Good for about 15 HP. Other than that, making more power is silly expensive on these bikes once you get past a dyno tune. Just grip it and rip it!:thumbsup:
well depends if you have a goal in mind, my bike put down 180hp to wheel, exhaust, power commander and a dyno tune......well worth it specially with 108lbs of tq
Learn to ride in the rpm range above 7K? To be honset, if you ring a Busa out like it was a 600 or something you will be going faster than even Rossi can handle, especially on the street!
IMHO once you get past an exhaust, filter, gearing change, and good tune every additional hp gets real expensive.
That interface looks good, but my local guy does PC3's and Bazzaz boxes mostly. I wonder if he feels comfortable with this or if I should spend the $ for a Bazzaz with traction control.
