How do you get away without running an oil evac pump?
SB911
For those of you without oil evac pumps, do you have anything special done with your return line?
I am putting an AirResearch turbo on a bike and I would prefer not to run a pump, the oil level will be about 5 inches lower than the turbo but the return line will be submerged in oil. Any tips or tricks? Thanks for any advice! :thumbsup:
:bowdown:
:bowdown:
If the turbo's oil return is higher than the engine's oil level,......you are okay. Most, if not all, oil lines are submerged in the oil at the pan. Good luck with your project.
