how does the gear sensor work?
Meta description: gear selector sensor
….10 yr old thread...Red Bull is having good luck in getting people to respond...
I know I know, I'm sure my gear position indicator is around the same age. I've been needing to redo some wiring and I was on the fence about getting a new GPi. I've seen that the pcv can tune by gear and was entertaining attempting to try to tune by gear and map.
Did some more web surfing and came up with this system on Bluegauges.com, which was pretty much what I was thinking about designing:
Gear Indicator Plans
Here's the text, and a couple of pics:
Notes:
This circuit is an example of how you can build a gear indicator for suzuki motorcycles which have an OEM gear position sensor (GPS). It basically uses comparators to compare the voltage coming from the GPS to predetermined levels and then will ground the negative lead of the appropriate LED on the display. The LED’s will be lit up in a continuous style (for example: 1st will light up the 1st LED, 2nd will light up the 1st and 2nd LED, 3rd will light up the 1st 2nd and 3rd LED’s, etc. etc.
An explanation of the parts required:
U1 = 5v regulator so that reference voltages do not vary with source voltage.
R1-R7 = The resistors form a ladder that breaks up the 5v from the voltage regulator (U1) into reference signals to determine at what voltages the LM339AN will use to ground each corresponding LED. It is important to use 1% resistors to make sure you get exact reference voltages because in the higher gears the signal is very close and there is not much gap between voltages:
The output voltages from the sensor are as follows
1st gear = 1.782v
2nd gear = 2.242v
3rd gear = 2.960v
4th gear = 3.630v
5th gear = 4.310v
6th gear = 4.660v
Neutral = 5.000v
The comparators in this circuit will turn on each LED as follows:
1st LED = Anything over 1.022v
2nd LED = Anything over 2.043v
3rd LED = Anything over 2.660v
4th LED = Anything over 3.356v
5th LED = Anything over 4.052v
6th LED = Anything over 4.526v
With this setup, Neutral will light up all 6 LEDs because it is over 4.526v. This is usually not a problem because it is difficult to get 6th gear and neutral confused. It can also be helpful because it will give you an indication if there is a false neutral situation. All lights will flicker on and off as you shift gears because for a brief instant you are in a false neutral.
R8-R13 are current limiting resistors for each display LED. This is to control the brightness of the LED and also prevents the LED’s from drawing too much current and burning out.
This circuit also has a built in dimming feature which is why there are (2) 12v sources. The first one supplies voltage to the circuit and also to the LED’s. It goes through a diode (D1) for reverse protection and then through R14. R14 keeps the LED’s dim for night riding when the high beams are usually off. It is required to be on a 12v source that is on whenever the bike is on. Since it is dark out, seeing the LED’s will not be hard. For daytime riding, when the high beams are usually on, the voltage comes from the 12v high beam circuit which also goes through a reverse protection diode (D2). There is no resistor here to allow the LED’s to shine at their maximum brightness for easy visibility in the daylight.
Per chiarezza, alcuni punti non sono stati collegati. Le lettere a, b, c, d, e o f devono essere collegate quando si costruisce il circuito.
hi dear, but is it possible to turn on only 1 led for each gear? if so how can I do it?
