how lean can i go at low boost levels?
I think i finally achieved the perfect tune...
The bike runs and accelerate like never before.
I must say that the PCV PTI (i have the plain PCV with boost input from the AEM wideband meter) with the autotune module works miracles on my Gen1 bike, especially if the initial map is rich enough to start safely.
I use the Boost based tuning and not the TPS based one.
Usually after the autotune calculate the changes needed and i am sure that they are correct, i incorporate them in to the ECU if the change affect the IAP map and to the split second box when on boost.
Thank you all for your valuable help.
Chris
