Ok so I was thinking about this today while I was out riding around earlier.
Assuming you even had time to react what is the best way to hit the pavement or to slide down the pavement?
For example...
If a car pulls out in front of you and you t-bone the car at a fairly high rate of speed. You then go over the top of the car and hit the pavement below.
Is it best to try to curl up in a ball?
Should you just go limp an let gravity take you?
Or should you fight it?
Or something else?
Any suggestions or experiences?
For example...
Or something else?
