mrninja9
Banned
ok there is a little plug you have for a 9volt battery find it and a 9volt. take your pc3 out and take it in your house next to the computer run your start up disc it sould say install power commander make sure you do that. then when that is done, hook the provided cable up to your usb port and double click the little usb icon. it should show like a graph ok now with your cable plugged in plug it in the pc3 and with your little 9volt cord plug it in to your pc3. it should say at the bottom that reading map..ok on the side it says get map no it will come up with a box look through those for your app. if you had a custom one installed then make sure it is there. but other than that find the stock ones for your application if you have any questions call
chris perdue
chris perdue
