Ludicrous Speed
Last year I pulled my front calipers to install new pads. When I did, one pad on one side was worn significantly more than the other in the same caliper. At this point I knew I had a sticky or stuck piston. I sprayed it really well with brake cleaner and pressed them all the way back in, but knew that this was just a temp fix.
So this winter I pulled the calipers off, and pulled them apart and gave em a good cleaning. Not that hard to do, and I took a few pics along the way.
This is not a difficult job, but it is extremely important that you take your time and inspect everything really closely. It is not even required that you replace the seals on the pistons, unless you have a leak, or damage one.
A friend that guided me through this has done dozens of sets of calipers and never had to replace a single seal.........
So anyway, onto the good stuff
