I'm guessing that it's a mighty vac pump...you suck fluid into the container until no more air is in the tube then top off the master cylinder.
Keep pumping until your getting straight , no bubbles, brake fluid in the container. Be sure to keep the master cylinder topped off and close the bleeder valve before you take the pump hose off.
Cool tools those Mity Vacs.
This keeps you from pumping the brakes for 30 minutes and beating you head on the wall trying to get all the air out of the line. Dont ask how I know.
Thanks guys. I bought one. $25.00 for the pump, container, and a dozen adapters.
How often should I change out the fluid? My bike is an 05 and the brakes feel OK, but I remember something about a complete fluid change at shorter intervals than this bike has had (0 changes).
Also, what about the hydraulic clutch?
Hows this for a guarantee: It will suck for two years.
