Hayabusa Wannabe
I removed the left muffler, the rear belly pan, unbolted the rectifier bracket and hung that out of the way. I did not want to disconnect it and cut all the cable ties if that is not necessary.
I tried a socket on the shock bolt but there is no room for it. I put a box wrench on it and pulled a bit but did not get any movement. I see a white dot, and think that indicates it is torqued to spec, but do these have thread lock? I applied penetrating oil to both shock bolts and all the joints on the bolt on top. Is this going to help? I think this is the scariest thing per the horror stories here of breaking frames.
Why is there a pipe clamp on the muffler pipe about six inches from the muffler? There is no joint there! Is it holding something between the pipe and the heat shield behind it?
