Upwards of $300. Try eBay or <a href="http://www.gpscity.com">GPS City<a>. I got lucky and got BT's.What does a GPS like that run you, I may need to put that on my Christmas list?
Kevin, I'm not really sure... The GPS is actually not mine... It's a friends. I just looked it up, and amazon.com has it for $253.01. Other places have it for $299.99, and the most expensive I've seen for THIS model (Garmin GPS V) was $350. Hope this helps.
Ninja Eater, That roads goes from east Florida to Lake Okeechobee. There's a few roads that do that. The *main* one is 441, which is where most of the traffic is, and this one is a little bit north of 441. If you look at a map, you'll notice that 441 goes west. This road branches off of 441 in a northwest direction. There's only factory's around that area, and traffic is very light. I just sat and waited after I saw a car pass by. I gave it a few good minutes before trying to top out the bike. This way I made sure that I would have enough room before catching up to traffic. Also, does anyone know any other good roads with low traffic, and low law enforcement where one could do highspeed runs here in Florida?
HayaGreg, Thanks. I held the throttle as long as I could before the TRE. I honestly didn't feel the bike "hit" a limiter. All I could feel was my jacket trying to pull me off the bike... The only thing was that the bike seemed to accelerate really slow once I was around 10,000 rpms in 6th gear... so I think that might have been the "limiter"... but I don't know... In my car, when I hit the limiter at 110mph, if feels as if I had slammed on the brakes... the rpms stop dead on their tracks, and go down to like 4,000. Then when the car goes down to 100mph, it starts accelerating again... This wasn't the case with the busa though... It just "stopped" accelerating. Very smooth though. I guess due to aerodynamics and the drag from my jacket, I couldnt hit the actual limiter at 185mph? I dunno... 183mph GPS was purdy fast enough for me.... at least for now
About the TRE, though... The thing is, I thought that the stock bike was limited to 185mph... is that ACTUAL 185 mph, or INDICATED 185mph... without the GPS, I hit 185 on the speedometer, and I assumed it "stopped" accelerating, but when I put the GPS on, I found out that wasn't the case... Even after the needle hit 185, the bike still accelerated. (I did a run at 168mph with the needle at 185, and another at 176mph with the needle also at 185). So I know that even without the TRE, the bike went past the 185 indicated. The problem then, is with the ACTUAL speed. With, or without the TRE, I STILL couldn't breake 185mph... hmmm... makes you wonder... For now, I'll blame the jacket, and the environment... I guess the wind wasn't in my favor, and the jacket created too much drag. (By the way, to get to 183mph ACTUAL speed, you gotta hold the throttle open for a good lil while AFTER the needle gets stuck at 185... at that speed the road goes by REALLY fast... so you gotta be careful... you gotta have big balls, but also a brain that helps you "untwist" the throttle for the sake of living another day... just a thought...) Remember... ALWAYS BE CAREFUL!
It's official... yer full of poop...Busaman86, Any idiot can twist the throttle and go fast. There is almost NOTHING related to skill needed.Yeah I said it. Cause it really is true. Given enough time we could easily train a chimp to go fast in a straight line.
Squeeking every last bit of MPH out of the Busa will take some fiddling, but it still takes very little riding skill... The only time skill or experiance will come into play is if something goes horribly wrong at those speeds.
Somewhat true, but it is still a lot of fun sometimes. I've never topped my R1 out. The fasted I've seen indicated is 172mph which probably equates to low 160s.Busaman86, Any idiot can twist the throttle and go fast. There is almost NOTHING related to skill needed.Yeah I said it. Cause it really is true. Given enough time we could easily train a chimp to go fast in a straight line.
Nice pics BTW.Did you have your seat cowling in place? AND your belly Fairing is intact yes? I mean you aren't using a Center stand are you? I'd be careful about being too specific about locations though, otherwise next time your out you'll find smokey everywhere...
Sometimes you open your mouth Bullet, and it's obvious your outta your depth. Talk to me when you have TOPPED SOMETHING OUT.... ANYTHING.... EVEN ONCE for FUGS Sake....It's official... yer full of ####...Busaman86, Any idiot can twist the throttle and go fast. There is almost NOTHING related to skill needed.Yeah I said it. Cause it really is true. Given enough time we could easily train a chimp to go fast in a straight line.
Depends on what topping out means. Those magic roads can be very nice.Sometimes you open your mouth Bullet, and it's obvious your outta your depth. Talk to me when you have TOPPED SOMETHING OUT.... ANYTHING.... EVEN ONCE for FUGS Sake....It's official... yer full of ####...Busaman86, Any idiot can twist the throttle and go fast. There is almost NOTHING related to skill needed.Yeah I said it. Cause it really is true. Given enough time we could easily train a chimp to go fast in a straight line.
<span style='color:red'>BusaMan86</span>... I wouldn't be talking SO MUCH #### if I hadn't been there many times myself. There is a perfect venue for such behaviour up here... Hell Maybe I am missing something, maybe the road I run is Magic... But I have found OVER AND OVER that topping out the Busa is pretty damned easy. NO DRAMA, Just takes some nerve.... I would say if your feeling like you have to fight your Busa along you in fact need to RELAX a bit, sounds like your actually interfering with your bikes stability... Holding on too tight. At those speeds it'll ride itself better without you, it doesn't need your help it has little use for you except holding open that throttle...
So NOT BAGGIN ON YOU BUSAMAN,I'm just saying that I have been there many times, and it's been my experiance that it really is just that easy... At least on a Busa.... Sounds like you had a good time, and that you have a good place for it...
