IG.
A while back I was complaining about this condition which I consistently notice as the brake pads get thinner - the lever needs to travel more before you feel it starts applying the pressure. I think that's what's happening.
As the pads wear out and get thinner, the pistons are being pushed further out taking along more brake fluid from the reservoir, and the vacuum inside the reservoir gets stronger and stronger. When the brake lever is released, that extra vacuum pulls the pistons slightly back in, which in turn creates an extra space between a piston and its respective pad. So, next time the lever is squeezed, there is a certain distance it needs to travel until the pistons get close to the pads again - which of course is waste of time and effort.
To combat this condition, all that needs to be done is to open the reservoir for a moment to get rid of the vacuum. Additionally, during the transition from warm weather to cold, the vacuum in the reservoir gets stronger - because the air temperature inside drops. This only makes it worse.
A good visual indication of the fact that there was vacuum in the reservoir once you open the cover would be the rubber membrane pulled down instead of being flat.
