I think I have a tranny problem
theskaz
I am all that is BACON!
Ok so.... If the bike is off and I pull the clutch in and move the bike, there is a clanking and the chain jerks kinda like a kink but it happens every foot or so the bike moves. if i put the bike in neutral, it doesnt do it. just in 1st and 2nd.
Also, I noticed that when the bike is running, there is a barely audible noise coming from my right ankle (where you put the oil in) only when the clutch is pulled in.
Any ideas?
ok just found out that is where the clutch packs are. and they are the ones making the clamking noise when the clutch is pulled.
umm....no? i didnt know there was a recall
My first bike didn't need it, but my second one did.
Thanks Kromeo, I was looking for that too.:beerchug:
Keven, check your S/N and see if you are in the range for the recall bulletin.
My first one was older and did not require it, but the second one I bought was within the range and the dealer gave me a receipt that showed the work had been done. You have to ask, because they certainly don't give up this bit of info.
I would probably go ahead check the bolts out anyway, just for peace of mind, and to eliminate that as the source.
Good luck, and see you soon Ya hoon!
Bubba
tranny problems are the worst!
Well i removed the cover and all the bolts were < hand tight. took em out and put some thread sealer on them and put them back in. in the process i snapped one of the little bolts that screw into the bigger ones. apparently they cant handle 16 ft/lb torque. will order one in the morning and get it by wednsday
ridgway,,nice call,,r-side with clutch depressed was a dead give away,,I didnt know about the recall either,,I know in cars with sticks,,depressed clutch chatter is ussually a fried throwout bearing,,,,Im glad kevin you got her torn down b4 it came completely unglued,,,,good job fellas,,,,
