loooooooooong hmmmmmmmmmmmmmmmm
you remember that the busa is no V8 /10 /12 ?
the two sounds i heard seem to me as normal and usual - for a genI.
genII´s exact sound i don´t remember in this moment - sorry. ;-)
yes at the genI the iddle jumps/varies a very little bit in a (feeled) dimension of i guess ~50 rpm´s or so - I personally never cared about it - I always accepted it as normal.
valve clearance set to max
throttles synchronized as fine as possible
and i have built the most precise synchronizer - completely from parts from the hardware store around the corner.
even the most expensive measuring instruments cannot be more precise,
because the physics alone works on my equipment.
the instruments in the purchased ones always have springs and therefore inevitable tolerances .
the only problem will rise if you have put the throttle-group into thousands pieces.
to synchronize after reassembling you need the "clock" instruments to achieve a basic setting , because my "big thing" gets rid of its fluid (motor oil) to one cylinder faster than youn stop the motor by the red switch.
so only ! use my tool after this basic setting !
I cannot say how the Carbtune will react to massively unsynchronized throttle valves - sorry - never used them before.
see this pic of my ~35" long "big thing"
and if you want you can get the carbtune as the alternative to my big thing
vantage - small in size and by that really easy to transport
it works on the same physical basis as mine above.
what i´m thinking about is to replace the X-screws by alen-screws
their advantage i guess should be that you need zero downforce to turn them contrary to the X-screws - ergo you have not to put any pressure onto for grip with your X-screwdriver (Philips).
even if you use this (highly recommended) "Vessel" X-screwdrivers who are built for the "JIS" - standard screws.
next time i have to syncho i will replace the screws (x to alen) before - promised ;-)
