Ok thanksYour idle looks normal to me but for giggles, I’ll go video my idle for ya here in a while.
What does the ecu flash and pc3 do ? I have pair valve removed , yosimira slip ins and k&n filter I wonder if one of those would help the low rpm stumble06 , synced tb, pair removed, all short stacks, airbox mod, k&n filter, 4-2-1 yosh with short can, ecu flash, pc3 can tune. Cold start , has not been run in weeks. Hope this helps
I may try a pc3 mine runs a little rich maybe l can play with it a littleEcu flash just changed the rev limiter and restrictions. Pc3 allows for fuel changes but the map I am using is generic.
Yes my Aussie friend, Gen 1's have a 'lumpy' idle compared with a Gen 2, which has an idle speed control valve, upgraded injection system etc.@Kiwi Rider - idles exactly like mine. So I think there's enough info to confirm, Gen 1's have a lumpy idle, period.
I've installed Woolich on mine, so I'll be playing around with tunes on my spare ECU, especially AFR in the lower RPM range. I'll unify the ignition curves (to remove restrictions on 1st and 2nd) and delete the top speed limiter (not that I intend on initiating warp factor 1 on the road).
Hey, I see you are in WA, are you in Perth?
Well, IF we ever open our borders again, let me know when you are arriving and I'd love to meet up and show you around . . . I even have a spare room if you get stuck, no worries.Yep, East Vic Park. I'll be coming to NZ in the near future after this Wuhan virus passes. Thanks for your input. Just went for a ride on my stocker and loved every second. Prefer it over my GSXR 1000.
Love my jis. Vessel screwdrivers.loooooooooong hmmmmmmmmmmmmmmmm
you remember that the busa is no V8 /10 /12 ?
the two sounds i heard seem to me as normal and usual - for a genI.
genII´s exact sound i don´t remember in this moment - sorry. ;-)
yes at the genI the iddle jumps/varies a very little bit in a (feeled) dimension of i guess ~50 rpm´s or so - I personally never cared about it - I always accepted it as normal.
valve clearance set to max
throttles synchronized as fine as possible
and i have built the most precise synchronizer - completely from parts from the hardware store around the corner.
even the most expensive measuring instruments cannot be more precise,
because the physics alone works on my equipment.
the instruments in the purchased ones always have springs and therefore inevitable tolerances .
the only problem will rise if you have put the throttle-group into thousands pieces.
to synchronize after reassembling you need the "clock" instruments to achieve a basic setting , because my "big thing" gets rid of its fluid (motor oil) to one cylinder faster than youn stop the motor by the red switch.
so only ! use my tool after this basic setting !
I cannot say how the Carbtune will react to massively unsynchronized throttle valves - sorry - never used them before.
see this pic of my ~35" long "big thing"
and if you want you can get the carbtune as the alternative to my big thing
vantage - small in size and by that really easy to transport
it works on the same physical basis as mine above.
what i´m thinking about is to replace the X-screws by alen-screws
their advantage i guess should be that you need zero downforce to turn them contrary to the X-screws - ergo you have not to put any pressure onto for grip with your X-screwdriver (Philips).
even if you use this (highly recommended) "Vessel" X-screwdrivers who are built for the "JIS" - standard screws.
next time i have to syncho i will replace the screws (x to alen) before - promised ;-)
Me too, just something special about 'em, good quality, I have a lot of Japanese made tools.Love my jis. Vessel screwdrivers.
All this talk about loving jis, holy fuuuuu**
.....and so my "to get list" continues to grow..smhView attachment 1617022
I love VESSEL Tools J.I.S too , learn from others they don't know View attachment 1617025
Vessel Magadora Impacta , HIT IT WITH A SMALL HAMMER AND LOOSE THE RESERVOIR J.I.S Bolts
