First the Aspect Ratio is located on your tire;
190/50zr17
The aspect ratio is the 50, meaning 50% of the width. Thus the normal busa tire height is 95mm, which defines the tire's profile(triangular vs rounded)
Now here's the REAL question what does this mean to a rider??
I searched on the web for hours and found very little info on what a tire's aspect ratio, or profile, does for the motorcycle. Here's all I could find;
"First of all, the most obvious characteristic is the width of the tire. The width, in concert with the diameter of the wheel, determines the size of the contact patch. The size of the contact patch in turn determines the load that the tire can bear, the amount of traction that will be available, how well the tire disperses water, and how much it resists steering inputs.
The diameter of the wheel and tire, in addition to its effect on the contact patch, affects the steering and stability of the bike. A larger wheel will be more stable at speed, and more resistant to steering inputs. This is in part due to the greater gyroscopic effect, but another factor is the greater contact patch caused by the larger wheel. In essence, a larger diameter wheel creates a longer contact patch, which requires more leverage to move.
The aspect ratio of the tire is the distance from the bead of the tire to the tread surface divided by the nominal width. In general, it describes the profile of the tire's cross-section; a lower aspect ratio means a flatter profile.
The profile of the tire is affected by several elements: the aspect ratio, the wheel width, the width of the tire, and the manufacturers intentions for the tire. The profile in turn affects the handling. A triangular profile will cause the bike to turn in more easily, but may make it a little more prone to tucking or falling into the turn. On the other hand, a rounder profile may be a little more difficult to turn in, but might have a little more linear response to steering inputs. This is to a great extent motorcycle dependent -- some bikes may like a particular tire, others may not."
Since 190/55 are going to become more common, I've been trying to research everything the aspect ratio changes. I will probably change to 190/55 since I love to lean.
Any comments??
I know there is some vast tire knowledge out there
190/50zr17
Any comments??
