They have run out of things to argue about can't you tell![]()
Gotta love this place.
Assuming that the surfaces are comprised of the same material (tire compound and pavement) and assuming they are equal temperature and the force (weight)pressing them together is the same, the friction generated is the same regardless of surface area contact.
Regardless of the common assumptions of the motorcycling community ((Tufbusa)) and tire manufacture babble this is BASIS physic and has been proven for hundreds of years.
Laws of dry friction
The elementary properties of sliding (kinetic) friction were discovered by experiment in the 15th to 18th centuries and were expressed as three empirical laws:
Amontons' First Law: The force of friction is directly proportional to the applied load.
Amontons' Second Law: The force of friction is independent of the apparent area of contact.
Coulomb's Law of Friction: Kinetic friction is independent of the sliding velocity.
cheers
ken
Okay, I'll bite! So tire size and contact size has no effect on grip and a bicycle tire has the same grip as a 200/50 series MC tire
Assuming you have not overloaded the bicycle tire, and the weight both tires are supporting is the same, say 100 pounds on each tire, and assuming the coefficient of friction is the same (ie, the tires are constructed with the same tread compound) then the force required to over come the friction generated is the same for both tires regardless of surface area.
Chat with your local high school physics teacher or ask at a physics forum.
cheers
ken
"Assuming" you never overload your tire, one would "Assume" you will never have issues with grip? Your "Assumption" of grip takes you all the way to the scene of the crash, eh? :dunno"
Oh Please, spare me the sermon! Go back and read the OP. This googled copy & paste tidbit of physics has absolutely nothing to do with how enlarging tire size on a standard rim affects contact patch which directly affects grip.
Next time you visit the man in the black suit wearing a bowtie ask him about your ability to comprehend. ???
Okay, I'll bite! So tire size and contact size has no effect on grip and a bicycle tire has the same grip as a 200/50 series MC tire.
Then explain to me why throttle is required while at maximum lean angle?
Oh, and that dumb a$$ Keith Code tells us to apply throttle as soon as the steering is complete. Why?
I'm sure there is at least one Genius in the bunch?
