David Offor
That mesh is pretty bad but there's also a filter in the black plastic moulded assembly next to the pump, there's a mod you can do to bypass that filter because it's stupid expensive from Suzuki, if your tank was very rusty and that lower mesh is bad, I'd say you should look into either replacing or carrying out the filter modification on that fine filter, also the rust eats fuel pumps, I'd be testing your pump pressure on your output side, once the tank is back together, this could be your problem.
