And that's cool. To each their own. I don't truly agree with H2O being injected into a motor either, hence why I use straight denatured alcohol. If water was good then why is water in gas bad?? I agree with you on the H2O part.
"tell me why a methanol injected car freezes the intake up on it at the end of a run " It's in the location of the injectors. If you notice I mentioned my intake freezes up as well running the alky injection kit. Methanol has greater cooling properties over ethanol so what you said above doesn't surprise me. Injecting either at the head just doesn't give you the full benefit of cooling air charge. Moving the injectors closer to the throttle bodies will allow for better atomization in turn cooling the charge more.
Now on the new 2008 busa's the secondary injectors are placed closer to the throttle bodies meaning with E85 you will see all the all same benefits of the alky injection without having to use an injection kit. I personally don't like using piggy back systems and that is what the alky kit is in my opinion. But like I keep saying, for those that don't have a new 2008 busa and that can't find E85 near them this is an option.
I wasn't trying to argue with you but you brought opened a whole other can of worms when it come to this particular discussion. The type of fuel wasn't one of things in consideration when the thread first opened. My initial thoughts were based between Injection and the Air to Air Intercooler.
A few of use that have experience with turbo applications should get together sometime and write up all the advantaged and disadvantaged with each part of a turbo application. Meaning from the type of header, the turbo, how to cool the air charge, internal or external wastegate, BOVs, intake manifolds, pistons, heads etc. This definatly isn't the thread for that though.
Again I didn't mean to piss ya off. I thought it was just a good debate.
