SS14PSI
A relay will not solve your problem, it is just another way to wire the fans. It appears that you are sending too much Amperage (potetially Voltage) through the switch which would result in it getting hot. The hot switch merely indicates that your bike is potentially wired incorrectly. Being wired incorrectly could also result in draining the battery.
If you review the description of how GIXERHP has his setup wired, yours should be set up pretty much the same (although it is possible to go about the 24V setup differently the harness he has is ideal). If your system is wired like his, you do not need a relay.
If however you have wired the fans directly to the battery(s) with the switch in the middle of the circuit, I would highly recommend a relay. For the record, wiring it this way is far less ideal and potentially trouble prone than what GIXERHP has done. I do not recommend this type of design.
So, back to my original question, how are your fans wired?
--Sky
Thanks for the info. As for your question, I don't know yet. I've been working like crazy the last few days so as soon as I get a chance I'll yank off the fairing and find out how it's wired. I didn't build the motor/fan setup so I have no idea how it's wired. I'll post up as soon as I figure out how it was done. Thanks again for the input, much appreciated.
