Jumps when shifting into first
speeder72
First Busa and notice that when I shift into first bike seems to want to lurch a little.Not sure if this is normal the clutch seems fine otherwise.
all bikes do that, put down the worry beads
jkjk
A small clunk is normal going into first but anything more could be the clutch not releasing enough. Does the bike lurch or try to creep forward? Where does the lever engage? If it's real close to the bar you may want to try bleeding it.
whats the rpms at idle when warm does it happen when cold ?
