Today's update. Pulled the sprocket cover off and checkedf the clutch actuator and rod. Rod seemed to move in and out with not problems, but the actuator was a different story. Pulled the clutch lever and the actuator did not move! It was completed at the recess of the its slot. Used some compressed air and a rubber mallet and finally got it out. Going to reassemble and see if I can bleed the line. Hopefully it will solve the problem.
