On the other end of the spectrum, 14-67 LOLI run a 20 front 95% of the time
Landspeed my setup is usually 20-38
Hi. Do you have the overdrive 5 th and 6 th gears? What is your rear tire? I am looking at running a car tire. Michelin pilot sport cup connect 215/45/17 with a y speed rating of over 186 MPH. Overall diameter 24.62 circumference 77.34.I run a 20 front 95% of the time
Gear set in bike is standard ratiosHi. Do you have the overdrive 5 th and 6 th gears? What is your rear tire? I am looking at running a car tire. Michelin pilot sport cup connect 215/45/17 with a y speed rating of over 186 MPH. Overall diameter 24.62 circumference 77.34.
Hi. What is your rev limit sey at? DME sets there's at 13500. I had Corrillo make my custon rods for 1000HP and 13500 RPM.Gear set in bike is standard ratios
Other motor has OD gears
I run a 190/55 that I have never measured
I am not worried about it till I run out of gear and revs haven't yet
Limit is wherever I set it. Best run at Loring was 10,600 rpm in fifth with the 20x38. So I have a while before I worry about itHi. What is your rev limit sey at? DME sets there's at 13500. I had Corrillo make my custon rods for 1000HP and 13500 RPM.
Hi. You can call me anytime you want. You ran right by my house at 977 Rockdale Ave. In the New Bedford 1/2 marathon. I was standing in the drivewayLimit is wherever I set it. Best run at Loring was 10,600 rpm in fifth with the 20x38. So I have a while before I worry about it
View attachment 1651691200/60-R17 vs 215/45-R17 Tire Comparison - Tire Size Calculator | Tacoma World
215/45-R17 tires are 1.83 inches (46.5 mm) smaller in diameter than 200/60-R17 tires and the speedometer difference is 6.9%www.tacomaworld.com
Hi RedBull. Thank you that was what I was looking for.View attachment 1651691200/60-R17 vs 215/45-R17 Tire Comparison - Tire Size Calculator | Tacoma World
