this is my good resistor bad melted down or overload i want to use a new resistor what should i use
YOU SHOULD USE 10 OHM 25 WATT RESISTORS. YOU CAN USE A HIGHER WATTAGE BUT PLEASE STICK TO 25. THE WAY YOU HAVE THEM WIRED IS WRONG. YOU PROBABLY HAVE 2 UNUSED RED WIRES LEFT BEHIND ON YOUR BIKE. YOU ARE SUPPOSED TO WIRE THE POSITIVE THROUGH ONE SIDE OF THE RESISTOR AND THE NEGATIVE TO THE OTHER. I could be wrong but i think im right.
Heres a diagram. You should run the positive in and back out one side of the resistor. Meaning cut the old light socket out, connect the hot wire to one side of the resistor and the hot from the led light to the same side. Then connect the ground to a metal source. You should have enought ground wires to connect the ground from the lights to any factory ground that you cut off the stock lights.
