Not to knock on Razor cause he was a stand up guy with mine. But here's the deal, to date nobody has been able to remove and replace the glass. So what he does is cut the mirror along the seam just behind the glass so that you end up with 2 pieces. He then etches the glass and installs the led's. After that, he uses black RTV to re-attach the 2 halves. Now the problem here is there is nothing really attaching your 2 halves but some silicone, and once you make your cut, and hopefully make it very straight, (not), when you put the mirror back together, the alignment is off due to the material that was removed from the cut, not off alot, but it is off. now due to the fact that some silicone is the only thing attaching your mirror parts, they flex (move) when you grab your mirror and try to adjust them, and in my best guess, will eventually seperate.
The led looked awesome and this procedure would best be done to a set of mirrors that were going to be painted afterwards where one could bondo over the seam and sand and smooth the edges out.
In case you haven't caught on yet, I wasn't very pleased with mine after recieving them, but Razor did step up and replace my money and a new set of mirrors without even questioning my dissatisfaction. As I said, stand-up guy.
So in the end, he had a set of mirrors he could do nothing with, returned my $$$, plus bought me a new set of mirrors to replace the one's I was unhappy with. So if you are all wondering why Razor isn't doing this mod anymore........................I'm probaby the reason
..............sorry.
