yzguyfl
could not pass up the opportunity to post this pic again...
This is the self stick led strips stuck to the inside of the fairings, except for the 2 above the back tire, those are directly on the frame there (I don't have the stock inner fender)
I also added 3" strips in the turn signal housing, but had to add a resistor inline to those to dim them down a bit to closer match the reflected light from the rest. (one set shows the turn signal lights without the resistors and you can see they are brighter)
I did not put any in the lower side opening, as it seemed really close to the exhaust.
I did cut the stock wires and add connectors near the lights, so I could remove the plastic.
I have 10 light strips total.
