I have always been slightly less comfortable in left hand turns. I attribute this to the fact left hand turns on the street always have a greater radius. As I judge how aggressively I'm cornering by lean angle, so for a given lean angle in any corner when you corner on the inside, as in a right hand turn, you are traveling slower that if you were to run the same corner, at the same lean angle, in the other direction where you are on the outside of the corner.
So for the same lean angle and the same corner just running the corner in opposite directions will cause an increase in speed when the corner is approached on the left hand. That fact, combined with the reduction in run off room, you don't have a full lane between you and the outside edge of the road, makes for me, the left hand turn to be less comfortable.
This doesn't apply on the track because regardless of the direction of the corner you can use the full width of the lane.
cheers
ken
cheers
ken
