That bike is 2012 L2 , bone stock when I got it end of 2013 3400km . It runs a DME aluminum subframe , lithium battery , aluminum kickstand and mount . Running standard tank with quick release mounts and stock bodywork , with carbon fairing trim and inner panels , pyramid plastics rear cowl cushion . Standard heat shield wrapped airbox , short stacks , woolich tuned 195bhp / 114 ftlb motor . Magical Racing carbon mirrors , cut F.Fabrai screen . BST front Black Diamond 5 spoke with ceramic bearings , Braketech 330mm Axis rotors , Brembo GP4-RX calipers . Fren Tubo Carbon lines and ceramic pads . Ohlins FGRT208 forks , CNC Racing carbon ducts . Agras top triple clamp , Gilles Vario Clipons , RCS Brembo brake and clutch pumps . CNC Racing carbon reservoirs . Agras carbon front guard , TWM fuel cap with Clever Wolf carbon tank protecter . Carbon frame guards ( forget maker ) Agras modified rearsets , reverse shift configured with quick shifter Cordona . Striker swingarm , with Agras rear uderslung bracker , Brembo billet P2 / 84MM caliper , Discacciati rear rotor . KFactory 47t sprocket , Healtech speedo healer ,EK 530 CHAIN . Front / swingarm pivot / rear axle in titanium , full engine mount bolts and covers in titanium , suspension linkage bolts in titanium , KFactory adjustable links , BST 6.25" rear with ceramic bearings , Full titanium and aluminum bolt replacement on all areas of bike , including all Brembo caliper factory bolts / rotor bolts , cush dive / spocket bolts / kickstand bolts , fork bolts / bodywork bolts , controls , subframe , rearsets and tank mounts all titanium / aluminum . Rear Ohlins TTX36 , Brocks CT Meg Ti exhaust . Think that might be clost to it mate .
