HighCaliberJordan
Thank you!
It is a tough pull to swallow. I asked many of the reputable vendors for Boosted Busas and put this kit together based on their recommendations. I am pretty sure the tuner smoked the engine by overly advancing the timing. He said the spark plug showed the toking mark at the 90 degree location on the plug strap indicating it is spot on after he added 3 degrees of timing to the table I received from one of the well known turbo hayabusa companies on this site.
I can’t say that I have ever added 3 degrees of timing across an entire map at once. Especially when I cannot verify timing somehow other than what the stand alone is saying. Either way though, it doesn’t change that it is blown up and given that it only made 217hp at 15psi, it would be hard for me to say it was all his fault and there was nothing wrong with the setup.
