Are you trying to print with the printer connected to a pc computer or via a direct USB connection to the mac?
I've tried both. I tried first to do it wirelessly without the PC at all, then I tried using a direct USB connection, then I tried using the PC as a host. Haven't been able to get it to work any of the 3 ways. It's really gotten me quite agrivated cause I'm fairly computer savy and can normally figure these things out, but the Mac OS is just something I'm not at all familiar with.
Use BootCamp. Install XP and you have a working, blazing fast laptop that is very stable. I know. I did the same thing.
Dude, I was a net admin for 10yrs+ switched to Macbook Pro (OS X) two years ago for my personal laptop, and I can tell you I would NEVER EVER EVER go back to microslow...![]()
Everyone has their preference. Mac OS is not mine.
Dumb question... but...
Did you follow the printer driver install exactly as per printer OS X instructions?
Can you call a printer tech line and go through the install with them, that would be ground zero, getting the printer to print via USB connection.
Well, I finally got it to work. The printer isn't compatible with the apple airport express, and I just messed around with the network connection some more and finally got it to recognize it. Now if I can just find some sort of other print server that's compatible with this ancient all-in-one I'll be good. Gonna do some reasearch and see what I can come up with. Thanks for all the help guys, I really do appreciate it. Believe it or not I've been working on this since about 2:30 or 3:00 this afternoon. I really like the Mackbook, I'll just have to get use to the system and find my way around it. Unfortunately it's my parent's computer so I probably won't get a whole lot of time to play with it.
Glad you got it cooking
Might be kinda tough to find a compatible print server with an older printer... Try to google it, and see if you can dig something up, good luck man![]()
