I have noticed in the last few days that, although my bike over-all runs very strong and smoothly and much better than stock, I do have a small hickup that seems to hit around 4000rpm.
To back up a little, I have an '03 with a full Micron system and a PCIIIR with the standard Micron map installed, no airbox mod. What seems to happen is right around 4K if I go from rather low throttle position (under say 40%) to a high throttle possition, the bike seems to hesitate a split second, and the harder you hit the throttle the more this hickup is noticeable. It only happens right around 4K and in any gear. The key is the throttle position. If you go from say 50-60% to wide open it does not happen.
I plan on getting a custom map when I can, but am I stuck for now or can I make a manual map mod that might help?
