dont be skeeerd of the bike man. a busa doesnt wheelie bad like most ppl would would have you believe. i mean if your in 1st gear cruising and pull on the throttle hard enough, yes its going to power wheelie but you're not driving down the highwya im sure in 1st. every other gear, you would have to pop the clutch to get it to wheelie unless maybe you doin 10k in 5th and quicky downshift to 3rd which if you ask me, is the same as popping the clutch, just more aggressive.
anyways if you on the highway you prolly in 5th or 6th gear. just downshift it one gear and give it a little throttle. its not going to come up. if you're doing under 5k, then you may want to downshift 2 gears to give you the rpms to speed up you're mph quickly.
all you really need to do i get out on a straight road with no traffic and practice what i told you. it should come naturally.
