micro throttle switch
gap4652
Just wondering where I can mount a micro throttle switch for my nitrous I have looked and figured and have not found a way to do can anyone help or show some pics of how they did it, Thanks in advance
http://www.tupeloperformancecycles.com/wot_switch.html
Another option is an electronic version that incorporates a TPS and rpm window switch together. Higher than using a micro switch, but the rpm window switch has many advantages.
Here ya go Gap, this may help too.
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i122.photobucket.com/player.swf?file=http://vid122.photobucket.com/albums/o244/narider/LSR/06%20Busa%20-%20LSR%201302/WOT%20Switch/100_4428.flv">
Todd
Thanks for the post! What year busa is this? I have an 08 and just cant seem to find room to make something work, and that looks like you did an excellent job!!!
My pleasure (just make sure you post up your results when you're done to help the next guy out). That one is on my wife's 2006... I'm not sure what the changes are on the 08 TB's though. It could actually be bolted to the rotating throttle shaft and the tang be depressed by a stud or bolt protruding somewhere along it's throw. Getting some help making something shouldn't be hard at all, snap a couple clean pics and post here.  If you fab a bracket yourself just start with construction paper or cardboard for your template.
I'm sure there's others out there that have already done it as well, so check on some of the other boards too.
The simplicity of what needs done is in the fact that (if not for the asthetics) it can be setup and done with a tang right off your throttle grip on the handlebars.
Todd
